Protocols NFS services endpoint overview
Retrieving an NFS configuration
# The API: GET /api/protocols/nfs/services # The call: curl -X GET "https://<mgmt-ip>/api/protocols/nfs/services"
Retrieving the mount permissions for a specified volume for a given IP address.
# The API: GET /api/protocols/nfs/services # The call: curl -X GET curl -X GET "https://<mgmt-ip>/api/protocols/nfs/services?protocol_access_rules.volume=testvol12&protocol_access_rules.client_ip=1.2.3.4&protocol_access_rules.auth_type=sys&svm.uuid=525928e9-9f84-11eb-a89f-005056bb70a8&fields=*&return_timeout=15&return_records=true" # Returns the protocol_access_rules structure and provides access permissions for each protocol. "protocol_access_rules": { "nfs3_access_type": "read_write", "nfs4_access_type": "read", "cifs_access_type": "read_write" }
Creating an NFS configuration for an SVM
# The API: POST /api/protocols/nfs/services # The call: curl -d "@test_nfs_post.txt" -X POST "https://<mgmt-ip>/api/protocols/nfs/services" test_nfs_post.txt(body): { "svm": { "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412" }, "protocol": { "v4_id_domain": "nfs-nsr-w01.rtp.netapp.com" }, "vstorage_enabled": "true" }
Updating an NFS configuration for an SVM
# The API: PATCH /api/protocols/nfs/services/{svm.uuid} # The call: curl -d "@test_nfs_patch.txt" -X PATCH "https://<mgmt-ip>/api/protocols/nfs/services/4a415601-548c-11e8-a21d-0050568bcbc9" test_nfs_patch.txt(body): { "protocol": { "v4_id_domain": "nfs-nsr-w01.rtp.netapp.com" }, "vstorage_enabled": "false" }
Deleting an NFS configuration for an SVM
# The API: DELETE /api/protocols/nfs/services/{svm.uuid} # The call: curl -X DELETE "https://<mgmt-ip>/api/protocols/nfs/services/4a415601-548c-11e8-a21d-0050568bcbc9"
Performance monitoring
Performance of the SVM can be monitored by the metric.*
and statistics.*
properties. These show the performance of the SVM in terms of IOPS, latency and throughput. The metric.*
properties denote an average whereas statistics.*
properties denote a real-time monotonically increasing value aggregated across all nodes.
