Protocols nfs services endpoint overview
Retrieving an NFS configuration
# The API: GET /api/protocols/nfs/services # The call: curl -X GET "https://<mgmt-ip>/api/protocols/nfs/services"
Creating an NFS configuration for an SVM
# The API:
POST /api/protocols/nfs/services
# The call:
curl -d "@test_nfs_post.txt" -X POST "https://<mgmt-ip>/api/protocols/nfs/services"
test_nfs_post.txt(body):
"svm": {
"protocol": {
"v4_id_domain": "nfs-nsr-w01.rtp.netapp.com"
"vstorage_enabled": "true"
Updating an NFS configuration for an SVM
# The API:
PATCH /api/protocols/nfs/services/{svm.uuid}
# The call:
curl -d "@test_nfs_patch.txt" -X PATCH "https://<mgmt-ip>/api/protocols/nfs/services/4a415601-548c-11e8-a21d-0050568bcbc9"
test_nfs_patch.txt(body):
"protocol": {
"vstorage_enabled": "false"
Deleting an NFS configuration for an SVM
# The API:
DELETE /api/protocols/nfs/services/{svm.uuid}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/nfs/services/4a415601-548c-11e8-a21d-0050568bcbc9"
Performance monitoring
Performance of the SVM can be monitored by the metric.* and statistics.* properties. These show the performance of the SVM in terms of IOPS, latency and throughput. The metric.* properties denote an average whereas statistics.* properties denote a real-time monotonically increasing value aggregated across all nodes.
