ONTAP REST API Protocols san vvol-bindings endpoints
Overview
A VMware virtual volume (vVol) binding is an association between a LUN of class protocol_endpoint and a LUN of class vvol. Class protocol_endpoint LUNs are mapped to igroups and granted access using the same configuration as class regular LUNs. When a class vvol LUN is bound to a mapped class protocol_endpoint LUN, VMware can access the class vvol LUN through the class protocol_endpoint LUN mapping.
Class protocol_endpoint and vvol LUNs support many-to-many vVol bindings. A LUN of one class can be bound to zero or more LUNs of the opposite class.
The vVol binding between any two specific LUNs is reference counted. When a REST POST is executed for a vVol binding that already exists, the vVol binding reference count is incremented. When a REST DELETE is executed, the vVol binding reference count is decremented. Only when the vVol binding count reaches zero, or the query parameter delete_all_references is supplied, is the vVol binding destroyed.
The vVol binding REST API allows you to create, delete, and discover vVol bindings.
Creating a vVol binding
# The API:
POST /api/protocols/san/vvol-bindings
# The call:
curl -X POST 'https://<mgmt-ip>/api/protocols/san/vvol-bindings' -H 'accept: application/hal+json' -d '{ "svm": { "name": "svm1" }, "protocol_endpoint": { "name": "/vol/vol1/pe1" }, "vvol" : { "name": "/vol/vol1/vvol1" } }'
Retrieving all vVol bindings
# The API:
GET /api/protocols/san/vvol-bindings
# The call:
curl -X GET 'https://<mgmt-ip>/api/protocols/san/vvol-bindings' -H 'accept: application/hal+json'
# The response:
"records": [
"uuid": "2aab57f3-dc5d-491e-80d2-15c7ed5dd5c4",
"name": "/vol/vol1/pe1",
"href": "/api/storage/luns/2aab57f3-dc5d-491e-80d2-15c7ed5dd5c4"
"vvol": {
"uuid": "28c02623-42fa-4f5f-a984-a02044bfc005",
"name": "/vol/vol1/vvol1",
"href": "/api/storage/luns/28c02623-42fa-4f5f-a984-a02044bfc005"
"href": "/api/protocols/san/vvol-bindings/2aab57f3-dc5d-491e-80d2-15c7ed5dd5c4/28c02623-42fa-4f5f-a984-a02044bfc005"
"vvol": {
"uuid": "a8d4ba93-918f-40ad-a1e4-4d7b244bdcdf",
"name": "/vol/vol1/vvol2",
"href": "/api/storage/luns/a8d4ba93-918f-40ad-a1e4-4d7b244bdcdf"
"href": "/api/protocols/san/vvol-bindings/2aab57f3-dc5d-491e-80d2-15c7ed5dd5c4/a8d4ba93-918f-40ad-a1e4-4d7b244bdcdf"
"num_records": 2,
"href": "/api/protocols/san/vvol-bindings"
Retrieving a specific vVol binding
# The API:
GET /api/protocols/san/vvol-bindings/{protocol_endpoint.uuid}/{vvol.uuid}
# The call:
curl -X GET 'https://<mgmt-ip>/api/protocols/san/vvol-bindings/2aab57f3-dc5d-491e-80d2-15c7ed5dd5c4/28c02623-42fa-4f5f-a984-a02044bfc005' -H 'accept: application/hal+json'
# The response:
"vvol": {
"svm": {
"uuid": "bf295ccc-a6bb-11eb-93e8-005056bb470f",
"name": "svm1",
"href": "/api/svm/svms/bf295ccc-a6bb-11eb-93e8-005056bb470f"
"id": 2411392,
"is_optimal": true,
"count": 1,
Deleting a vVol binding
# The API:
DELETE /api/protocols/san/vvol-bindings/{protocol_endpoint.uuid}/{vvol.uuid}
# The call:
curl -X DELETE 'https://<mgmt-ip>/api/protocols/san/vvol-bindings/2aab57f3-dc5d-491e-80d2-15c7ed5dd5c4/28c02623-42fa-4f5f-a984-a02044bfc005' -H 'accept: application/hal+json'
