Retrieve directories
Retrieve directories with the most IO activity for a specified volume using this API. Filter and order directory listings by IO activity types, such as iops or throughput, to gain insights into performance metrics. Remember, the API returns up to 25 directories per metric type, and tracking must be enabled for accurate results.
Overview
You can use this API to retrieve a list of directories with the most IO activity for a specified volume. Use the top_metric parameter to specify which type of IO activity to filter for. This API is used to provide insight into IO activity and supports ordering by IO activity types, namely iops and throughput metrics. This API supports only returning one IO activity type per request.
Retrieve a list of the directories with the most IO activity
For a report on the directories with the most IO activity returned in descending order, specify the performance metric type you want to filter for by passing the iops or throughput property into the top_metric parameter. If the metric type is not specified, by default the API returns a list of the directories with the greatest number of the average read operations per second. The maximum number of directories returned by the API for a metric type is 25.
Failure to return list of directories with most IO activity
The API can sometimes fail to return the list of directories with the most IO activity, due to the following reasons:
– The volume does not have the activity tracking feature enabled.
– The volume does not have read/write traffic.
– The read traffic is served by the NFS/CIFS client filesystem cache.
– On rare occasions, the incoming traffic pattern is not suitable to obtain the list of directories with the most IO activity.
– GET /api/storage/volumes/{volume.uuid}/top-metrics/directories
Failure to return the pathnames for the list of directories with most IO activity
The API can sometimes fail to obtain the filesystem pathnames for the list of directory entries, due to internal transient errors.
In such cases, instead of the pathname, the API will return "{
Retrieving a list of the directories with the greatest average number of read operations per second:
# The API:
# The Call:
curl -X GET "https://<mgmt-ip>/api/storage/volumes/{volume.uuid}/top-metrics/directories?top_metric=iops.read"
# The Response:
"records": [
"volume": {
"name": "vol1",
"iops": {
"read": 1495,
"error": {
"lower_bound": 1495,
"upper_bound": 1505
"path": "/dir1/dir2",
"svm": {
"uuid": "572361f3-e769-439d-9c04-2ba48a08ff43",
"name": "vs1",
"href": "/api/svm/svms/572361f3-e769-439d-9c04-2ba48a08ff43"
"directory": {
"href": "/api/storage/volumes/73b293df-e9d7-46cc-a9ce-2df8e52ef864/files/dir1%2Fdir2"
"metadata": {
"href": "/api/storage/volumes/73b293df-e9d7-46cc-a9ce-2df8e52ef864/files/dir1%2Fdir2?return_metadata=true"
"volume": {
"name": "vol1",
"iops": {
"read": 1022,
"error": {
"lower_bound": 1022,
"upper_bound": 1032
"path": "/dir3/dir4",
"svm": {
"name": "vs1",
"directory": {
"href": "/api/storage/volumes/73b293df-e9d7-46cc-a9ce-2df8e52ef864/files/dir3%2Fdir4"
"metadata": {
"href": "/api/storage/volumes/73b293df-e9d7-46cc-a9ce-2df8e52ef864/files/dir3%2Fdir4?return_metadata=true"
"volume": {
"uuid": "73b293df-e9d7-46cc-a9ce-2df8e52ef864",
"name": "vol1",
"href": "/api/storage/volumes/73b293df-e9d7-46cc-a9ce-2df8e52ef864"
"iops": {
"read": 345,
"error": {
"lower_bound": 345,
"upper_bound": 355
"path": "/dir12",
"svm": {
"name": "vs1",
"directory": {
"href": "/api/storage/volumes/73b293df-e9d7-46cc-a9ce-2df8e52ef864/files/dir12"
"metadata": {
"href": "/api/storage/volumes/73b293df-e9d7-46cc-a9ce-2df8e52ef864/files/dir12?return_metadata=true"
"num_records": 3,
"href": "/api/storage/volumes/73b293df-e9d7-46cc-a9ce-2df8e52ef864/top-metrics/directories?top_metric=iops.read"
Retrieving a list of the directories with the most traffic with failure in obtaining the pathnames for the directories:
# The Call:
curl -X GET "https://<mgmt-ip>/api/storage/volumes/{volume.uuid}/top-metrics/directories?top_metric=throughput.write"
# The Response:
"records": [
"volume": {
"name": "fv"
"throughput": {
"write": 24,
"error": {
"lower_bound": 24,
"upper_bound": 29
"path": "{4ec6d1ea-d5da-11eb-a25f-005056ac0f77:1232}",
"svm": {
"uuid": "0ba74c3e-d5ca-11eb-8fbb-005056ac0f77",
"name": "vs0",
"href": "/api/svm/svms/0ba74c3e-d5ca-11eb-8fbb-005056ac0f77"
"volume": {
"name": "fv"
"throughput": {
"write": 12,
"error": {
"lower_bound": 12,
"upper_bound": 22
"path": "{4ec6d1ea-d5da-11eb-a25f-005056ac0f77:6754}",
"svm": {
"name": "vs0",
"volume": {
"name": "fv"
"throughput": {
"write": 8,
"error": {
"lower_bound": 8,
"upper_bound": 10
"path": "{4ec6d1ea-d5da-11eb-a25f-005056ac0f77:8654}",
"svm": {
"name": "vs0",
"num_records": 3,
"href": "/api/storage/volumes/4ec6d1ea-d5da-11eb-a25f-005056ac0f77/top-metrics/directories?top_metric=throughput.write"
Example showing the behavior of the API when there is no read/write traffic:
# The Call:
# The Response:
"records": [
"num_records": 0,
"notice": {
"message": "The activity tracking report for volume \"FV\" in SVM \"vs0\" returned zero records. Check whether the volume have read/write traffic. Refer to the REST API documentation for more information on why there might be no records.",
"code": "124518418"
"href": "/api/storage/volumes/9af63729-8ac8-11ec-b1bc-005056a79da4/top-metrics/directories?top_metric=throughput.write"
