Retrieve directories
Use the Retrieve directories API to obtain a list of directories based on specified performance or capacity metrics within a volume. Filter for metrics like IOPS or throughput to gain insights into directory activity, or use capacity metrics such as non-recursive bytes used to identify large directories. The API returns results for one metric type per request, with a current maximum of 25 directories.
Overview
You can use this API to retrieve a list of directories with the most I/O activity for FlexVol and FlexGroup volumes belonging to a specified SVM, within the past several seconds. To obtain this list, only the volumes which have the activity tracking feature enabled are considered.
This API is used to provide insight into I/O activity and supports ordering by I/O activity types, namely iops and throughput metrics. Use the top_metric parameter to specify which type of I/O activity to filter for. This API supports returning only one I/O activity type per request.
Enabling and disabling activity tracking feature
The following APIs can be used to enable, disable, and retrieve the activity tracking state for a FlexVol or a FlexGroup volume.
– PATCH /api/storage/volumes/{uuid} -d '{"activity_tracking.state":"on"}'
– PATCH /api/storage/volumes/{uuid} -d '{"activity_tracking.state":"off"}'
– GET /api/storage/volumes/{uuid}/?fields=activity_tracking
Excluded volumes list
Optionally, the API returns an excluded list of activity tracking-enabled volumes, which were not accounted for when obtaining the list of clients with the most I/O activity for the SVM. This excluded list contains both the volume information and the reason for exclusion.
Approximate accounting and error bars
When too many directories have recent activity, some directories might be dropped from the list. In this situation, the spread of values in the error field increases, indicating that there are larger error bars on the value for iops or throughput. As the list becomes increasingly more approximate due to dropped entries, some of the directories that would have otherwise been included might not be present in the final list returned by the API.
Failure to return list of directories with most I/O activity
The API can sometimes fail to return the list of directories with the most I/O activity, due to the following reasons:
– The volumes belonging to the SVM do not have the activity tracking feature enabled.
– The volumes belonging to the SVM have not had any recent NFS/CIFS client traffic.
– The NFS/CIFS client operations are being served by the client-side filesystem cache.
– The NFS/CIFS client operations are being buffered by the client operating system.
– On rare occasions, the incoming traffic pattern is not suitable to obtain the list of directories with the most I/O activity.
Failure to return pathnames
The API can sometimes fail to obtain filesystem pathnames for certain directories, either due to internal transient errors or if those directories have been recently deleted.
In such cases, instead of the pathname, the API will return "{
Retrieve a list of the directories with the most I/O activity
For a report on the directories with the most I/O activity returned in descending order, specify the I/O activity type you want to filter for by passing the iops or throughput property into the top_metric parameter. If the I/O activity type is not specified, by default the API returns a list of directories with the greatest number of average read operations per second. The current maximum number of directories returned by the API for an I/O activity type is 25.
– GET /api/svm/svms/{svm.uuid}/top-metrics/directories
Retrieving a list of the directories with the greatest average number of read operations per second:
# The API:
# The Call:
curl -X GET "https://<mgmt-ip>/api/svm/svms/{svm.uuid}/top-metrics/directories?top_metric=iops.read"
# The Response:
"records": [
"svm": {
"name": "vs1"
"iops": {
"read": 1495,
"error": {
"lower_bound": 1495,
"upper_bound": 1505
"path": "/vol/fv1/dir1/dir2",
"junction-path": "/fv1",
"volume": {
"name": "fv1",
"uuid": "73b293df-e9d7-46cc-a9ce-2df8e52ef86",
"href": "/api/storage/volumes/73b293df-e9d7-46cc-a9ce-2df8e52ef86"
"directory": {
"href": "/api/storage/volumes/73b293df-e9d7-46cc-a9ce-2df8e52ef864/files/dir1%2Fdir2"
"metadata": {
"href": "/api/storage/volumes/73b293df-e9d7-46cc-a9ce-2df8e52ef864/files/dir1%2Fdir2?return_metadata=true"
"svm": {
"name": "vs1"
"iops": {
"read": 1022,
"error": {
"lower_bound": 1022,
"upper_bound": 1032
"path": "/vol/fv2/dir3/dir4",
"junction-path": "/fv2",
"volume": {
"name": "fv2",
"uuid": "11b293df-e9d7-46cc-a9ce-2df8e52ef811",
"href": "/api/storage/volumes/11b293df-e9d7-46cc-a9ce-2df8e52ef811"
"directory": {
"href": "/api/storage/volumes/11b293df-e9d7-46cc-a9ce-2df8e52ef811/files/dir3%2Fdir4"
"metadata": {
"href": "/api/storage/volumes/11b293df-e9d7-46cc-a9ce-2df8e52ef811/files/dir3%2Fdir4?return_metadata=true"
"svm": {
"name": "vs1"
"iops": {
"read": 345,
"error": {
"lower_bound": 345,
"upper_bound": 355
"path": "/vol/fv1/dir12",
"volume": {
"name": "fv1",
"uuid": "73b293df-e9d7-46cc-a9ce-2df8e52ef864",
"href": "/api/storage/volumes/73b293df-e9d7-46cc-a9ce-2df8e52ef864"
"directory": {
"href": "/api/storage/volumes/73b293df-e9d7-46cc-a9ce-2df8e52ef864/files/dir12"
"metadata": {
"href": "/api/storage/volumes/73b293df-e9d7-46cc-a9ce-2df8e52ef864/files/dir12?return_metadata=true"
"num_records": 3,
"excluded_volumes": [
"volume": {
"uuid": "5bbfc226-3fd8-42c9-a651-fa6167c2cf84",
"name": "vol10",
"href": "/api/storage/volumes/5bbfc226-3fd8-42c9-a651-fa6167c2cf84"
"reason": {
"message": "The volume is offline.",
"code": 12345
"volume": {
"uuid": "5bbfc227-3fd8-42c9-a651-fa6167c2cf85",
"name": "vol22",
"href": "/api/storage/volumes/5bbfc227-3fd8-42c9-a651-fa6167c2cf85"
"reason": {
"code": 23456
"href": "/api/svm/svms/572361f3-e769-439d-9c04-2ba48a08ff43/top-metrics/directories?top_metric=iops.read"
Retrieving a list of the directories with the most read traffic, with failure to obtain pathnames
# The Call:
# The Response:
"records": [
"svm": {
"name": "vs1"
"iops": {
"read": 1495,
"error": {
"upper_bound": 1505
"path": "73b293df-e9d7-46cc-a9ce-2df8e52ef86.1232",
"volume": {
"name": "fv1",
"svm": {
"name": "vs1"
"iops": {
"read": 1022,
"error": {
"upper_bound": 1032
"path": "11b293df-e9d7-46cc-a9ce-2df8e52ef811.6574",
"volume": {
"name": "fv2",
"svm": {
"name": "vs1"
"iops": {
"read": 345,
"error": {
"lower_bound": 345,
"upper_bound": 355
"path": "73b293df-e9d7-46cc-a9ce-2df8e52ef864.7844",
"volume": {
"name": "fv1",
"num_records": 3,
"volume": {
"name": "vol10",
"reason": {
"code": 12345
"volume": {
"name": "vol22",
"reason": {
"code": 23456
Example showing the behavior of the API where there is no read/write traffic:
# The Call:
curl -X GET "https://<mgmt-ip>/api/svm/svms/{svm.uuid}/top-metrics/directories?top_metric=throughput.write"
# The Response:
"records": [
"num_records": 0,
"notice": {
"message": "The activity tracking report for SVM \"vs1\" returned zero records. Check whether the activity tracking enabled volumes belonging to the SVM have read/write traffic. Refer to the REST API documentation for more information on why there might be no records.",
"code": "124519405",
"href": "/api/svm/svms/572361f3-e769-439d-9c04-2ba48a08ff43/top-metrics/directories?top_metric=throughput.write"
