ONTAP REST API Support ems destinations endpoints
Overview
Manages the list of destinations. A destination is defined by a type and a place to which an event's information is transmitted.
Destination Types
An EMS destination is defined by a single type, which is one of the following:
email
syslog
rest_api
snmp
The 'email' type allows you to define a mailbox where information about an observed event is sent by SMTP. Enter the address in the destination field in a valid format. For example: administrator@mycompany.com
Syslog
The 'syslog' type allows you to specify a remote syslog server that can receive information about an observed event. Enter the hostname or IP address in the destination field. For example: syslog.mycompany.com, 192.168.1.1
Rest API
The 'rest_api' type allows you to define a URL where information about an observed event is sent using the REST protocol. Enter the URL in the destination field. The URL must contain a valid transmission schema which can be one of the following:
http
https Using the 'https' schema, you can configure a client-side certificate for mutual authentication. For example: http://rest.mycompany.com, https://192.168.1.1
SNMP
The 'snmp' type describes addresses where information about an observed event is sent using SNMP traps. The system defines a default instance of this type and it is restricted to read-only. This type has the following limitations:
Cannot create new destinations of type 'snmp'
Cannot modify the default 'snmp' destination
SNMP trap host details need to be configured through one of the following:
| Type | Command / API |
CLI |
'system snmp traphost' |
ZAPI |
'snmp-traphost-add' / 'snmp-traphost-delete' |
Retrieving the list of active destinations
# API
GET /api/support/ems/destinations
# Response
200 OK
# JSON Body
"records": [
"name": "snmp-traphost",
"href": "/api/support/ems/destinations/snmp-traphost"
"num_records": 1,
"href": "/api/support/ems/destinations"
Creating a new 'email' destination
# API
POST /support/ems/destinations
# JSON Body
"name": "Technician_Email",
"type": "email",
"destination": "technician@mycompany.com",
"filters": [
{ "name" : "critical-wafl" }
# Response
201 Created
