Manage event destinations
Manage the list of destinations to which event information is transmitted. By defining destination types such as email, syslog, rest_api, and snmp, you can direct event data to specific locations for monitoring and alerting purposes.
Overview
Manages the list of destinations. A destination is defined by a type and a place to which an event's information is transmitted.
Destination Types
An EMS destination is defined by a single type, which is one of the following:
email
syslog
rest_api
snmp
The 'email' type allows you to define a mailbox where information about an observed event is sent by SMTP. Enter the address in the destination field in a valid format. For example: administrator@mycompany.com
Syslog
The 'syslog' type allows you to specify a remote syslog server that can receive information about an observed event. Enter the hostname or IP address in the destination field. For example: syslog.mycompany.com, 192.168.1.1
You can optionally specify the port and transport protocol to be used. The supported transport protocols are:
udp_unencrypted
tcp_unencrypted
tcp_encrypted
If transport is specified and the port is not specified, the default port for each transport is automatically selected. The default port for udp_unencrypted is 514, for tcp_unencrypted 601, and for tcp_encrypted 6514. The default transport protocol is udp_unencrypted.
The message format to be used can also be optionally specified. The supported message formats are:
legacy_netapp (format: <PRIVAL>TIMESTAMP [HOSTNAME:Event-name:Event-severity]: MSG)
rfc_5424 (format: <PRIVAL>VERSION TIMESTAMP HOSTNAME Event-source - Event-name - MSG)
If the default timestamp or hostname formats in the message format needs to be overridden, use timestamp_override and hostname_override properties.
The supported timestamp formats are:
no_override (timestamp format based on the syslog.format.message property i.e. rfc_3164 if syslog.format.message is legacy_netapp, iso_8601_local_time if syslog.format.message is rfc_5424)
rfc_3164 (format: Mmm dd hh:mm:ss)
iso_8601_local_time (format: YYYY-MM-DDThh:mm:ss+/-hh:mm)
iso_8601_utc (format: YYYY-MM-DDThh:mm:ssZ)
The supported hostname formats are:
no_override (hostname format based on the syslog.format.message property i.e. fqdn if syslog.format.message is rfc_5424, hostname_only if syslog.format.message is legacy_netapp)
fqdn (Fully Qualified Domain Name)
hostname_only
Rest API
The 'rest_api' type allows you to define a URL where information about an observed event is sent using the REST protocol. Enter the URL in the destination field. The URL must contain a valid transmission schema which can be one of the following:
http
https
Using the https schema, you can configure a client-side certificate for mutual authentication. A client-side certificate is specified by the ca and serial_number fields in the certificate object. The name field of the certificate object is read-only and cannot be used to configure a client-side certificate.
For example: http://rest.mycompany.com, https://192.168.1.1
SNMP
The 'snmp' type describes addresses where information about an observed event is sent using SNMP traps. The system defines a default instance of this type and it is restricted to read-only. This type has the following limitations:
Cannot create new destinations of type 'snmp'
Cannot modify the default 'snmp' destination
SNMP trap host details need to be configured through one of the following:
| Type | Command / API |
CLI |
'system snmp traphost' |
ZAPI |
'snmp-traphost-add' / 'snmp-traphost-delete' |
Retrieving the list of active destinations
# The API:
GET /api/support/ems/destinations
# The call:
curl -X GET "https://<mgmt-ip>/api/support/ems/destinations" -H "accept: application/hal+json"
# The response:
200 OK
# JSON Body
"records": [
"name": "snmp-traphost",
"href": "/api/support/ems/destinations/snmp-traphost"
"num_records": 1,
"href": "/api/support/ems/destinations"
Creating a new 'email' destination
# The API:
POST /support/ems/destinations
# The call:
curl -X POST "https://<mgmt-ip>/api/support/ems/destinations" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_destinations_post.txt"
test_ems_destinations_post.txt(body):
# JSON Body
"name": "Technician_Email",
"type": "email",
"destination": "technician@mycompany.com",
"filters": [
{ "name" : "critical-wafl" }
# The response:
201 Created
Creating a new 'syslog' destination
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/support/ems/destinations" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_destinations_syslog_post.txt"
test_ems_destinations_syslog_post.txt(body):
# JSON Body
"name": "Syslog_dest",
"type": "syslog",
"destination": "syslog.mycompany.com",
"syslog": {
"port": 601,
"transport": "tcp_unencrypted",
"format": {
"message": "rfc_5424",
"hostname_override": "fqdn",
"timestamp_override": "iso_8601_local_time"
"filters": [
# The response:
201 Created
