REST API reference
View and update audit settings
Control the logging of operations to audit log files through these endpoints. All changes are consistently logged and cannot be disabled, ensuring comprehensive audit trails. Use PATCH requests to update audit settings for GET requests, where all fields are optional, and GET requests to retrieve the current settings.
Overview
This API controls what is logged to the audit log files. All operations that make changes are always logged and cannot be disabled. The PATCH request updates administrative audit settings for GET requests. All fields are optional for a PATCH request. A GET request retrieves administrative audit settings for GET requests.
Retrieving administrative audit settings for GET requests
The following example shows the administrative audit settings for GET requests.
# The API:
/api/security/audit
# The call:
curl -X GET "https://<cluster-ip>/api/security/audit"
# The response:
"cli": false,
"http": false,
"ontapi": false,
        "href": "/api/security/audit"
Updating administrative audit settings for GET requests
The following example updates the administrative audit settings for GET requests
# The API:
/api/security/audit
# The call:
curl -X PATCH "https://<cluster-ip>/api/security/audit" -d '{"cli":"false", "http": "true", "ontapi": "true"}'
