View and update audit settings
Control logging parameters for audit log files to track changes made to administrative settings. Use these endpoints to retrieve or update audit settings for GET requests, ensuring all operations that make changes are consistently documented.
Overview
This API controls what is logged to the audit log files. All operations that make changes are always logged and cannot be disabled. The PATCH request updates administrative audit settings for GET requests. All fields are optional for a PATCH request. A GET request retrieves administrative audit settings for GET requests.
Retrieving administrative audit settings for GET requests
The following example shows the administrative audit settings for GET requests.
# The API:
/api/security/audit
# The call:
curl -X GET "https://<cluster-ip>/api/security/audit"
# The response:
"cli": false,
"http": false,
"ontapi": false,
"href": "/api/security/audit"
Updating administrative audit settings for GET requests
The following example updates the administrative audit settings for GET requests
# The API:
/api/security/audit
# The call:
curl -X PATCH "https://<cluster-ip>/api/security/audit" -d '{"cli":"false", "http": "true", "ontapi": "true"}'
