ONTAP REST API Cluster sensors node.uuid index endpoints
Overview
You can use this API to retrieve the details of all platform environment sensors
Retrieving values of a single sensor
# The API:
GET /api/cluster/sensors/{node.uuid}/{index}
# The call:
curl -X GET "https://<mgmt-ip>/api/cluster/sensors/{node.uuid}/{index}" -H "accept: application/hal+json"
# The response:
200 OK
# JSON Body
"node": {
"uuid": "19ec0b4a-4a4d-11ec-9036-d039ea4a991a",
"name": "node1",
"href": "/api/cluster/nodes/19ec0b4a-4a4d-11ec-9036-d039ea4a991a"
"index": 1,
"name": "PVCCSA CPU FD",
"type": "voltage",
"value": 831,
"value_units": "mV",
"threshold_state": "normal",
"critical_low_threshold": 297,
"warning_low_threshold": 396,
"warning_high_threshold": 1485,
"critical_high_threshold": 1683,
"href": "/api/cluster/sensors/19ec0b4a-4a4d-11ec-9036-d039ea4a991a/1"
