Manage environment sensors
Retrieve detailed information about platform environment sensors within your cluster using this API. These endpoints help you monitor sensor readings to ensure optimal system performance and anticipate potential hardware issues.
Overview
You can use this API to retrieve the details of all platform environment sensors
Retrieving values of a single sensor
# The API:
GET /api/cluster/sensors/{node.uuid}/{index}
# The call:
curl -X GET "https://<mgmt-ip>/api/cluster/sensors/{node.uuid}/{index}" -H "accept: application/hal+json"
# The response:
200 OK
# JSON Body
"node": {
"uuid": "19ec0b4a-4a4d-11ec-9036-d039ea4a991a",
"name": "node1",
"href": "/api/cluster/nodes/19ec0b4a-4a4d-11ec-9036-d039ea4a991a"
"index": 1,
"name": "PVCCSA CPU FD",
"type": "voltage",
"value": 831,
"value_units": "mV",
"threshold_state": "normal",
"critical_low_threshold": 297,
"warning_low_threshold": 396,
"warning_high_threshold": 1485,
"critical_high_threshold": 1683,
"href": "/api/cluster/sensors/19ec0b4a-4a4d-11ec-9036-d039ea4a991a/1"
