Deletes the ldap configuration of the specified svm ldap can be removed as a source from the ns-switch if ldap is not used as a source for lookups
DELETE /name-services/ldap/{svm.uuid}
Introduced In: 9.6
Deletes the LDAP configuration of the specified SVM. LDAP can be removed as a source from the ns-switch if LDAP is not used as a source for lookups.
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
