REST API reference
Delete LDAP configuration for an SVM
Deletes the LDAP configuration for a specified SVM when LDAP is no longer needed as a lookup source.
HTTP method and endpoint
DELETE /name-services/ldap/{svm.uuid}
Introduced in
ONTAP 9.6
Usage notes
Deletes the LDAP configuration of the specified SVM. LDAP can be removed as a source from the ns-switch if LDAP is not used as a source for lookups.
svm.uuid
string
path
True
Status: 200, Ok
Status: Default, Error
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
