Delete an existing schema
DELETE /name-services/ldap-schemas/{owner.uuid}/{name}
Introduced In: 9.11
Deletes an existing schema.
Related ONTAP commands
vserver services name-service ldap client schema delete
owner.uuid |
string |
path |
True |
UUID of the owner to which this object belongs. |
name |
string |
path |
True |
LDAP schema name. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
4915204 |
Failed to delete. The LDAP schema is being used by at least one LDAP client configuration. |
4915205 |
The LDAP schema is a default schema and cannot be modified or deleted. |
4915217 |
LDAP schema is owned by the admin SVM. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
