REST API reference
Delete an existing schema
Deletes an existing schema to remove its configuration from the system. Use this when you need to clean up or reorganize schema resources.
HTTP method and endpoint
DELETE /name-services/ldap-schemas/{owner.uuid}/{name}
Introduced in
ONTAP 9.11
  • vserver services name-service ldap client schema delete
owner.uuid
string
path
True
UUID of the owner to which this object belongs.
name
string
path
True
LDAP schema name.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
4915204
Failed to delete. The LDAP schema is being used by at least one LDAP client configuration.
4915205
The LDAP schema is a default schema and cannot be modified or deleted.
4915217
LDAP schema is owned by the admin SVM.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
