Delete a BGP peer group for VIP
Removes a BGP peer group for VIP, which is useful when managing or updating network configurations.
HTTP method and endpoint
DELETE /network/ip/bgp/peer-groups/{uuid}
Introduced in
ONTAP 9.7
Usage notes
Deletes a BGP peer group for VIP.
Related ONTAP commands
network bgp peer-group delete
uuid |
string |
path |
True |
UUID of the peer group |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
53282019 |
Internal error. Failed to remove BGP peer group on node. Wait a few minutes and try the command again. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
