REST API reference
Delete a BGP peer group for VIP
Deletes a BGP peer group for VIP, removing the peer group configuration associated with virtual IPs in your network setup.
HTTP method and endpoint
DELETE /network/ip/bgp/peer-groups/{uuid}
Introduced in
ONTAP 9.7
  • network bgp peer-group delete
uuid
string
path
True
UUID of the peer group
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
53282019
Internal error. Failed to remove BGP peer group on node. Wait a few minutes and try the command again.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
