REST API reference
Delete an audit configuration
Deletes an audit configuration to remove its settings from the system when it's no longer needed.
HTTP method and endpoint
DELETE /protocols/audit/{svm.uuid}
Introduced in
ONTAP 9.6
  • vserver audit disable
  • vserver audit delete
force
boolean
query
False
Indicates to force delete audit configuration.
  • Introduced in: 9.10
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
svm.uuid
string
path
True
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
9699349
Auditing should be disabled before deleting the audit configuration
9699350
Audit configuration cannot be deleted, final consolidation is in progress
9699410
Failed to disable multiproto.audit.evtxlog.support support capability
9699430
Failed to disable multiproto.audit.cifslogonlogoff.support support capability
9699433
Failed to disable multiproto.audit.capstaging.support support capability
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
