Delete an audit configuration
Deletes an audit configuration to manage or remove auditing settings that are no longer required.
HTTP method and endpoint
DELETE /protocols/audit/{svm.uuid}
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver audit disable -
vserver audit delete
Learn more
force |
boolean |
query |
False |
Indicates to force delete audit configuration.
return_timeout |
integer |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
9699349 |
Auditing should be disabled before deleting the audit configuration |
9699350 |
Audit configuration cannot be deleted, final consolidation is in progress |
9699410 |
Failed to disable multiproto.audit.evtxlog.support support capability |
9699430 |
Failed to disable multiproto.audit.cifslogonlogoff.support support capability |
9699433 |
Failed to disable multiproto.audit.capstaging.support support capability |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
