REST API reference
Delete a local group configuration for an SVM
Removes a local group configuration from a specified SVM. Use this operation when you need to manage or reorganize your SVM's group configurations.
HTTP method and endpoint
DELETE /protocols/cifs/local-groups/{svm.uuid}/{sid}
Introduced in
ONTAP 9.10
Usage notes
Deletes a local group configuration for the specified SVM.
  • vserver cifs users-and-groups local-group delete
sid
string
path
True
Local group SID
svm.uuid
string
path
True
Status: 200, Ok
Status: Default, Error
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
