Delete a local group configuration for an SVM
Removes a local group configuration from a specified SVM. Use this operation when you need to manage or reorganize your SVM's group configurations.
HTTP method and endpoint
DELETE /protocols/cifs/local-groups/{svm.uuid}/{sid}
Introduced in
ONTAP 9.10
Usage notes
Deletes a local group configuration for the specified SVM.
Related ONTAP commands
vserver cifs users-and-groups local-group delete
Learn more
sid |
string |
path |
True |
Local group SID |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
