Delete a UNIX symbolic link mapping for CIFS clients
Deletes a UNIX symbolic link mapping for CIFS clients when you need to remove an existing mapping configuration.
HTTP method and endpoint
DELETE /protocols/cifs/unix-symlink-mapping/{svm.uuid}/{unix_path}
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver cifs symlink delete
Learn more
unix_path |
string |
path |
True |
UNIX symbolic link path |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
