REST API reference
Delete a UNIX symbolic link mapping for CIFS clients
Deletes a UNIX symbolic link mapping for CIFS clients when you need to remove an existing mapping configuration.
HTTP method and endpoint
DELETE /protocols/cifs/unix-symlink-mapping/{svm.uuid}/{unix_path}
Introduced in
ONTAP 9.6
  • vserver cifs symlink delete
unix_path
string
path
True
UNIX symbolic link path
svm.uuid
string
path
True
Status: 200, Ok
Status: Default, Error
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
