Remove a nested initiator group from an initiator group
Removes a nested initiator group from its parent initiator group, dissolving the relationship between the two. Use this endpoint when you need to manage or reorganize initiator group configurations without deleting the nested group itself.
HTTP method and endpoint
DELETE /protocols/san/igroups/{igroup.uuid}/igroups/{uuid}
Introduced in
ONTAP 9.9
Usage notes
Removes a nested initiator group from an initiator group. This API does not delete the nested initiator group itself. It removes the relationship between a parent and child initiator group. This API only supports removal of initiator groups owned directly by the initiator group. Further nested initiator groups must be removed from the direct parent initiator group.
Related ONTAP commands
lun igroup remove
Learn more
igroup.uuid |
string |
path |
True |
The unique identifier of the parent initiator group. |
uuid |
string |
path |
True |
The unique identifier of the nested initiator group. |
allow_delete_while_mapped |
boolean |
query |
False |
Allows the deletion of a nested initiator group from of a mapped initiator group. Deleting a nested initiator group from a mapped initiator group means that the LUNs, to which the initiator group is mapped, are no longer available to the initiators nested below the initiator group being removed. This might cause a disruption in the availability of data. This parameter should be used with caution.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1254213 |
The initiator group is mapped to one or more LUNs and |
5374738 |
The child initiator group is not owned by the parent initiator group. |
5374852 |
The initiator group specified in the URI does not exist. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
