REST API reference
Remove a nested initiator group from an initiator group
Removes a nested initiator group from a parent initiator group, altering the parent-child relationship without deleting the nested group itself. This action is useful for reorganizing or updating your initiator group configurations.
HTTP method and endpoint
DELETE /protocols/san/igroups/{igroup.uuid}/igroups/{uuid}
Introduced in
ONTAP 9.9
Usage notes
Removes a nested initiator group from an initiator group. This API does not delete the nested initiator group itself. It removes the relationship between a parent and child initiator group.
This API only supports removal of initiator groups owned directly by the initiator group. Further nested initiator groups must be removed from the direct parent initiator group.
  • lun igroup remove
igroup.uuid
string
path
True
The unique identifier of the parent initiator group.
uuid
string
path
True
The unique identifier of the nested initiator group.
allow_delete_while_mapped
boolean
query
False
Allows the deletion of a nested initiator group from of a mapped initiator group.
Deleting a nested initiator group from a mapped initiator group means that the LUNs, to which the initiator group is mapped, are no longer available to the initiators nested below the initiator group being removed. This might cause a disruption in the availability of data.
This parameter should be used with caution.
  • Default value:
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1254213
The initiator group is mapped to one or more LUNs and allow_delete_while_mapped has not been specified.
5374738
The child initiator group is not owned by the parent initiator group.
5374743
LUN maps exist for a parent initiator group.
5374852
The initiator group specified in the URI does not exist.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
