REST API reference
Delete an initiator from an initiator group
Deletes an initiator from an initiator group to manage the membership of initiators within the group. This operation is supported for initiators directly owned by the group, ensuring precise control over initiator assignments.
HTTP method and endpoint
DELETE /protocols/san/igroups/{igroup.uuid}/initiators/{name}
Introduced in
ONTAP 9.6
Usage notes
This API only supports removal of initiators owned directly by the initiator group. Initiators of nested initiator groups must be removed on the initiator group that directly owns the initiator.
  • lun igroup remove
igroup.uuid
string
path
True
The unique identifier of the initiator group.
name
string
path
True
The name of the initiator to delete.
allow_delete_while_mapped
boolean
query
False
Allows the deletion of an initiator from of a mapped initiator group.
Deleting an initiator from a mapped initiator group makes the LUNs to which the initiator group is mapped no longer available to the initiator. This might cause a disruption in the availability of data.
This parameter should be used with caution.
  • Default value:
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1254213
The initiator group is mapped to one or more LUNs and allow_delete_while_mapped has not been specified.
5374034
An initiator is not a member of the initiator group.
5374041
The initiator is not owned by the supplied initiator group.
5374852
The initiator group specified in the URI does not exist.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
