Delete an initiator from an initiator group
Removes an initiator from an initiator group. Use this endpoint to manage initiator group memberships and streamline your storage configurations.
HTTP method and endpoint
DELETE /protocols/san/igroups/{igroup.uuid}/initiators/{name}
Introduced in
ONTAP 9.6
Usage notes
Deletes an initiator from an initiator group. This API only supports removal of initiators owned directly by the initiator group. Initiators of nested initiator groups must be removed on the initiator group that directly owns the initiator.
Related ONTAP commands
lun igroup remove
Learn more
igroup.uuid |
string |
path |
True |
The unique identifier of the initiator group. |
name |
string |
path |
True |
The name of the initiator to delete. |
allow_delete_while_mapped |
boolean |
query |
False |
Allows the deletion of an initiator from of a mapped initiator group. Deleting an initiator from a mapped initiator group makes the LUNs to which the initiator group is mapped no longer available to the initiator. This might cause a disruption in the availability of data. This parameter should be used with caution.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1254213 |
The initiator group is mapped to one or more LUNs and |
5374034 |
An initiator is not a member of the initiator group. |
5374041 |
The initiator is not owned by the supplied initiator group. |
5374852 |
The initiator group specified in the URI does not exist. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
