Delete an antivirus On-Access policy configuration
DELETE /protocols/vscan/{svm.uuid}/on-access-policies/{name}
Introduced In: 9.6
Deletes the anti-virus On-Access policy configuration.
Related ONTAP commands
vserver vscan on-access-policy delete
Name | Type | In | Required | Description |
name |
string |
path |
True |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code | Description |
10027034 |
An On-Access policy associated with an administrative SVM cannot be deleted. |
10027040 |
An On-Access policy with a status enabled cannot be deleted. Disable the policy and then delete the policy. |
Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
