REST API reference
Delete an antivirus On-Access policy configuration
Deletes an antivirus On-Access policy configuration when you need to remove a policy that no longer aligns with your security requirements.
HTTP method and endpoint
DELETE /protocols/vscan/{svm.uuid}/on-access-policies/{name}
Introduced in
ONTAP 9.6
Usage notes
Deletes the anti-virus On-Access policy configuration.
  • vserver vscan on-access-policy delete
name
string
path
True
svm.uuid
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
10027034
An On-Access policy associated with an administrative SVM cannot be deleted.
10027040
An On-Access policy with a status enabled cannot be deleted. Disable the policy and then delete the policy.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
