REST API reference
Delete remote syslog or splunk server information
Removes the information for a remote syslog or Splunk server, typically when the server is no longer needed or requires reconfiguration.
HTTP method and endpoint
DELETE /security/audit/destinations/{address}/{port}
Introduced in
ONTAP 9.6
Usage notes
Deletes remote syslog/splunk server information.
address
string
path
True
IP address of remote syslog/splunk server.
port
integer
path
True
Port number of remote syslog/splunk server.
Status: 200, Ok
Status: Default, Error
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
