Delete the remote syslog or splunk server information
Removes the information for a remote syslog or Splunk server, typically when the server is no longer needed or requires reconfiguration.
HTTP method and endpoint
DELETE /security/audit/destinations/{address}/{port}
Introduced in
ONTAP 9.6
Usage notes
Deletes remote syslog/splunk server information.
address |
string |
path |
True |
IP address of remote syslog/splunk server. |
port |
integer |
path |
True |
Port number of remote syslog/splunk server. |
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
