Delete security certificates
Deletes a security certificate when it is no longer needed or requires replacement.
HTTP method and endpoint
DELETE /security/certificates/{uuid}
Introduced in
ONTAP 9.6
Related ONTAP commands
security certificate delete
uuid |
string |
path |
True |
Certificate UUID |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
3735644 |
Cannot delete server-chain certificate. Reason: There is a corresponding server certificate for it. |
3735679 |
Cannot delete pre-installed server_ca certificates through REST. Use CLI or ZAPI. |
3735650 |
Deleting this client_ca certificate directly is not supported. Delete the corresponding root-ca certificate using type |
3735627 |
Deleting this server_ca certificate directly is not supported. Delete the corresponding root-ca certificate using type |
3735589 |
Cannot delete certificate. |
3735590 |
Cannot delete certificate. Failed to remove SSL configuration for the certificate. |
3735683 |
Cannot remove this certificate while external key manager is configured. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
