REST API reference
Delete security certificates
Deletes a security certificate when it is no longer needed or if you want to replace it with a new one.
HTTP method and endpoint
DELETE /security/certificates/{uuid}
Introduced in
ONTAP 9.6
  • security certificate delete
uuid
string
path
True
Certificate UUID
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
3735644
Cannot delete server-chain certificate. Reason: There is a corresponding server certificate for it.
3735679
Cannot delete pre-installed server_ca certificates through REST. Use CLI or ZAPI.
3735650
Deleting this client_ca certificate directly is not supported. Delete the corresponding root-ca certificate using type root_ca to delete the root, client, and server certificates.
3735627
Deleting this server_ca certificate directly is not supported. Delete the corresponding root-ca certificate using type root_ca to delete the root, client, and server certificates.
3735589
Cannot delete certificate.
3735590
Cannot delete certificate. Failed to remove SSL configuration for the certificate.
3735683
Cannot remove this certificate while external key manager is configured.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
