Remove a cloud target from an aggregate
Removes a cloud target from an aggregate, specifically targeting the removal of a mirror. This operation initiates a job and provides you with a link to track its progress.
HTTP method and endpoint
DELETE /storage/aggregates/{aggregate.uuid}/cloud-stores/{target.uuid}
Introduced in
ONTAP 9.6
Usage notes
Removes the specified cloud target from the aggregate. Only removal of a mirror is allowed. The primary cannot be removed. This request starts a job and returns a link to that job.
Related ONTAP commands
storage aggregate object-store unmirror
aggregate.uuid |
string |
path |
True |
Aggregate UUID |
target.uuid |
string |
path |
True |
Cloud target UUID |
return_timeout |
integer |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
