REST API reference
Remove a cloud target from an aggregate
Removes a cloud target from an aggregate when you need to unmirror the specified storage, initiating a job to complete this operation.
HTTP method and endpoint
DELETE /storage/aggregates/{aggregate.uuid}/cloud-stores/{target.uuid}
Introduced in
ONTAP 9.6
Usage notes
Removes the specified cloud target from the aggregate. Only removal of a mirror is allowed. The primary cannot be removed. This request starts a job and returns a link to that job.
  • storage aggregate object-store unmirror
aggregate.uuid
string
path
True
Aggregate UUID
target.uuid
string
path
True
Cloud target UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
3
Invalid operation
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
