REST API reference
Delete a LUN
Deletes a LUN to remove it from your storage configuration when it is no longer needed.
HTTP method and endpoint
DELETE /storage/luns/{uuid}
Introduced in
ONTAP 9.6
  • lun copy cancel
  • lun delete
Learn more
uuid
string
path
True
The unique identifier of the LUN to retrieve.
allow_delete_while_mapped
boolean
query
False
Allows deletion of a mapped LUN.
A mapped LUN might be in use. Deleting a mapped LUN also deletes the LUN map and makes the data no longer available. This might cause a disruption in the availability of data.
This parameter should be used with caution.
  • Default value:
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1254197
The LUN is mapped and cannot be deleted without specifying the allow_delete_while_mapped query parameter.
5374705
Deleting the LUN is not allowed because it is part of an application.
5374865
The LUN's aggregate is offline. The aggregate must be online to modify or remove the LUN.
5374866
The LUN's volume is offline. The volume must be online to modify or remove the LUN.
5374875
The specified LUN was not found.
5374876
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
