Delete a LUN
DELETE /storage/luns/{uuid}
Introduced In: 9.6
Deletes a LUN.
Related ONTAP commands
lun copy cancel -
lun delete
Learn more
uuid |
string |
path |
True |
The unique identifier of the LUN to retrieve. |
allow_delete_while_mapped |
boolean |
query |
False |
Allows deletion of a mapped LUN. A mapped LUN might be in use. Deleting a mapped LUN also deletes the LUN map and makes the data no longer available. This might cause a disruption in the availability of data. This parameter should be used with caution.
return_timeout |
integer |
query |
False |
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1254197 |
The LUN is mapped and cannot be deleted without specifying the |
5374705 |
Deleting the LUN is not allowed because it is part of an application. |
5374865 |
The LUN's aggregate is offline. The aggregate must be online to modify or remove the LUN. |
5374866 |
The LUN's volume is offline. The volume must be online to modify or remove the LUN. |
5374875 |
The specified LUN was not found. |
5374876 |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
