Delete a LUN
DELETE /storage/luns/{uuid}
Deletes a LUN.
Related ONTAP commands
lun delete
Learn more
uuid  |
string  |
path  |
True  |
The unique identifier of the LUN.  |
allow_delete_while_mapped  |
boolean  |
query  |
False  |
Allows deletion of a mapped LUN. A mapped LUN might be in use. Deleting a mapped LUN also deletes the LUN map and makes the data no longer available. This might cause a disruption in the availability of data. This parameter should be used with caution.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1254197  |
The LUN is mapped and cannot be deleted without specifying the   |
5374705  |
Deleting the LUN is not allowed because it is part of an application.  |
5374865  |
The LUN's aggregate is offline. The aggregate must be online to modify or remove the LUN.  |
5374866  |
The LUN's volume is offline. The volume must be online to modify or remove the LUN.  |
5374875  |
The specified LUN was not found.  |
5374876  |
| Name | Type | Description |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
