Retrieve MetroCluster status and configuration details
Accesses the current status and configuration details of a MetroCluster, which helps in monitoring and managing the cluster's health and setup.
HTTP method and endpoint
GET /cluster/metrocluster
Introduced in
ONTAP 9.8
Usage notes
Retrieves MetroCluster status and configuration details.
Related ONTAP commands * metrocluster show * metrocluster node show
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
local |
remote |
"href": "/api/resourcelink"
"local": {
"cluster": {
"name": "cluster1",
"configuration_state": "string",
"mode": "string"
"remote": {
"cluster": {
"name": "cluster1",
"mode": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2425734 |
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
_links
self |
node
Local node of the DR Group.
_links |
name |
string |
uuid |
string |
partner
Partner node of the DR Group.
_links |
name |
string |
uuid |
string |
dr_pairs
node |
Local node of the DR Group. |
partner |
Partner node of the DR Group. |
cluster
_links |
name |
string |
uuid |
string |
local
cluster |
configuration_state |
string |
Indicates the state of the local cluster configuration. |
mode |
string |
Specifies the mode of operation of the local cluster. |
partner_cluster_reachable |
boolean |
Specifies whether the partner cluster is reachable from the local cluster. |
periodic_check_enabled |
boolean |
Indicates whether or not a periodic check is enabled on the local cluster. |
ipv4_interface
Object to setup an interface along with its default router.
address |
string |
IPv4 or IPv6 address |
gateway |
string |
The IPv4 or IPv6 address of the default router. |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length. |
l3_config
ipv4_interface |
Object to setup an interface along with its default router. |
node
Node information
_links |
name |
string |
uuid |
string |
mccip_ports
Port configuration specification. l3_config information is only needed when configuring a MetroCluster IP for use in a layer 3 network.
l3_config |
name |
string |
Port name |
node |
Node information |
uuid |
string |
Port UUID |
vlan_id |
integer |
VLAN ID |
dr_group
DR group reference.
id |
integer |
DR Group ID |
peer_cluster
The peer cluster that the mediator service is used for.
_links |
name |
string |
uuid |
string |
mediator
Mediator information
dr_group |
DR group reference. |
ip_address |
string |
The IP address of the mediator. |
peer_cluster |
The peer cluster that the mediator service is used for. |
peer_mediator_connectivity |
string |
Indicates the mediator connectivity status of the peer cluster. Possible values are connected, unreachable, unknown. |
port |
integer |
The REST server's port number on the mediator. |
reachable |
boolean |
Indicates the connectivity status of the mediator. |
uuid |
string |
The unique identifier for the mediator service. |
partner_cluster
Partner cluster information.
_links |
name |
string |
uuid |
string |
remote
cluster |
string |
Indicates the state of the remote cluster configuration. |
mode |
string |
Specifies the mode of operation of the remote cluster. |
boolean |
Indicates whether or not a periodic check is enabled on the remote cluster. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
