REST API reference
Retrieve MetroCluster status and configuration details
Retrieves MetroCluster status and configuration details to monitor and manage your MetroCluster environment effectively.
HTTP method and endpoint
GET /cluster/metrocluster
Introduced in
ONTAP 9.8
  • metrocluster show
  • metrocluster node show
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
configuration_type
string
Displays the MetroCluster configuration type.
encryption_enabled
boolean
Indicates if the encryption for NVLog and storage traffic is enabled.
local
local
remote
remote
      "href": "/api/resourcelink"
  "configuration_type": "string",
  "local": {
    "automatic_uso_failure_domain": "string",
    "cluster": {
      "name": "cluster1",
    "configuration_state": "string",
    "mode": "string"
  "remote": {
    "cluster": {
      "name": "cluster1",
    "mode": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
2425734
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
self
node
Local node of the DR Group.
_links
_links
name
string
uuid
string
partner
Partner node of the DR Group.
_links
_links
name
string
uuid
string
dr_pairs
node
node
partner
partner
cluster
_links
_links
name
string
uuid
string
local
string
This parameter specifies the configuration of automatic switchover. The valid values for the parameter are ':' cluster':' triggers an unplanned switchover if all nodes in a DR cluster are down. dr_group':' triggers an unplanned switchover if both nodes of a DR group are down. disabled':' automatic switchover is disabled. If the cluster is not reachable due to errors, the parameter value will be set to not_reachable. This value is read only. If the cluster configuration is unknown, the parameter value will be set to unknown and the value is read only.
cluster
cluster
configuration_state
string
Indicates the state of the local cluster configuration.
mode
string
Specifies the mode of operation of the local cluster.
partner_cluster_reachable
boolean
Specifies whether the partner cluster is reachable from the local cluster.
periodic_check_enabled
boolean
Indicates whether or not a periodic check is enabled on the local cluster.
ipv4_interface
Object to setup an interface along with its default router.
address
string
IPv4 or IPv6 address
gateway
string
The IPv4 or IPv6 address of the default router.
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length.
l3_config
ipv4_interface
ipv4_interface
node
Node information
_links
_links
name
string
uuid
string
mccip_ports
Port configuration specification. l3_config information is only needed when configuring a MetroCluster IP for use in a layer 3 network.
l3_config
l3_config
name
string
Port name
node
node
Node information
uuid
string
Port UUID
vlan_id
integer
VLAN ID
dr_group
DR group reference.
id
integer
DR Group ID
peer_cluster
The peer cluster that the mediator service is used for.
_links
_links
name
string
uuid
string
mediator
Mediator information
dr_group
dr_group
DR group reference.
ip_address
string
The IP address of the mediator.
peer_cluster
peer_cluster
peer_mediator_connectivity
string
Indicates the mediator connectivity status of the peer cluster. Possible values are connected, unreachable, unknown.
port
integer
The REST server's port number on the mediator.
reachable
boolean
Indicates the connectivity status of the mediator.
uuid
string
The unique identifier for the mediator service.
partner_cluster
Partner cluster information.
_links
_links
name
string
uuid
string
remote
string
cluster
cluster
configuration_state
string
Indicates the state of the remote cluster configuration.
mode
string
Specifies the mode of operation of the remote cluster.
boolean
Indicates whether or not a periodic check is enabled on the remote cluster.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
