Retrieve a global name service cache setting
Retrieves a global name service cache setting to view the current configuration and usage of the cache for name services.
HTTP method and endpoint
GET /name-services/cache/setting
Introduced in
ONTAP 9.11
Usage notes
Retrieves a global nameservice cache setting.
Related ONTAP commands
vserver services name-service cache settings show
Learn more
eviction_time_interval |
string |
query |
False |
Filter by eviction_time_interval |
remote_fetch_enabled |
boolean |
query |
False |
Filter by remote_fetch_enabled |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
string |
Specifies the time interval, in ISO 8601 format after which a periodic cache eviction happens. Default is 4 hours. |
boolean |
Indicates whether or not a node is allowed to fetch the data from a remote node. |
"href": "/api/resourcelink"
"eviction_time_interval": "PT2H"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
