REST API reference
Retrieve a global name service cache setting
GET /name-services/cache/setting
Introduced In: 9.11
Retrieves a global nameservice cache setting.
  • vserver services name-service cache settings show
remote_fetch_enabled
boolean
query
False
Filter by remote_fetch_enabled
eviction_time_interval
string
query
False
Filter by eviction_time_interval
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
string
Specifies the time interval, in ISO 8601 format after which a periodic cache eviction happens. Default is 4 hours.
boolean
Indicates whether or not a node is allowed to fetch the data from a remote node.
      "href": "/api/resourcelink"
  "eviction_time_interval": "PT2H"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
