REST API reference
Retrieves fc wwpn aliases
learn more
  • [doc /network/fc/wwpn-aliases](#docs-san-network_fc_wwpn-aliases)
GET /network/fc/wwpn-aliases
Introduced In: 9.6
Retrieves FC WWPN aliases.
  • vserver fcp wwpn-alias show
wwpn
string
query
False
Filter by wwpn
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
alias
string
query
False
Filter by alias
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
The number of records in the response.
records
array[wwpn_alias]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "alias": "host1",
      "svm": {
        "name": "svm1",
      "wwpn": "2f:a0:00:a0:98:0b:56:13"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
wwpn_alias
A Fibre Channel (FC) world wide port name (WWPN) alias. A WWPN is a unique 64-bit identifier for an FC initiator. It is displayed as a 16-character hexadecimal value. SAN administrators may find it easier to identify FC initiators using an alias, especially in larger SANs.
_links
_links
alias
string
The FC WWPN alias. Required in POST.
svm
svm
wwpn
string
The FC initiator WWPN. Required in POST.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
