Retrieve FC WWPN aliases
GET /network/fc/wwpn-aliases
Introduced In: 9.6
Retrieves FC WWPN aliases.
Related ONTAP commands
vserver fcp wwpn-alias show
Learn more
alias |
string |
query |
False |
Filter by alias |
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
wwpn |
string |
query |
False |
Filter by wwpn |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
The number of records in the response. |
records |
array[wwpn_alias] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"alias": "host1",
"svm": {
"name": "svm1",
"wwpn": "2f:a0:00:a0:98:0b:56:13"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
_links |
name |
string |
uuid |
string |
wwpn_alias
A Fibre Channel (FC) world wide port name (WWPN) alias. A WWPN is a unique 64-bit identifier for an FC initiator. It is displayed as a 16-character hexadecimal value. SAN administrators may find it easier to identify FC initiators using an alias, especially in larger SANs.
_links |
alias |
string |
The FC WWPN alias. Required in POST. |
svm |
wwpn |
string |
The FC initiator WWPN. Required in POST. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
