REST API reference
Retrieve the audit configuration for an SVM
Retrieves the audit configuration for a storage virtual machine (SVM) to review existing audit settings or to ensure compliance with security policies.
HTTP method and endpoint
GET /protocols/audit/{svm.uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves an audit configuration for an SVM.
  • vserver audit show
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
enabled
boolean
Specifies whether or not auditing is enabled on the SVM.
events
events
guarantee
boolean
Indicates whether there is a strict Guarantee of Auditing
log
log
log_path
string
The audit log destination path where consolidated audit logs are stored.
svm
svm
  "guarantee": "",
  "log": {
        "href": "/api/resourcelink"
    "format": "string",
    "retention": {
      "duration": "P4DT12H30M5S"
    "rotation": {
      "schedule": {
        "days": [
          "integer"
        "hours": [
          "integer"
        "minutes": [
          "integer"
        "months": [
          "integer"
        "weekdays": [
          "integer"
  "log_path": "string",
  "svm": {
    "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
events
authorization_policy
boolean
Authorization policy change events
cap_staging
boolean
Central access policy staging events
cifs_logon_logoff
boolean
CIFS logon and logoff events
file_operations
boolean
File operation events
file_share
boolean
File share category events
security_group
boolean
Local security group management events
user_account
boolean
Local user account management events
string
self
retention
count
integer
Determines how many audit log files to retain before rotating the oldest log file out. This is mutually exclusive with duration.
duration
string
Specifies an ISO-8601 format date and time to retain the audit log file. The audit log files are deleted once they reach the specified date/time. This is mutually exclusive with count.
audit_schedule
Rotates the audit logs based on a schedule by using the time-based rotation parameters in any combination. The rotation schedule is calculated by using all the time-related values.
days
array[integer]
Specifies the day of the month schedule to rotate audit log. Leave empty for all.
hours
array[integer]
Specifies the hourly schedule to rotate audit log. Leave empty for all.
minutes
array[integer]
Specifies the minutes schedule to rotate the audit log.
months
array[integer]
Specifies the months schedule to rotate audit log. Leave empty for all.
weekdays
array[integer]
Specifies the weekdays schedule to rotate audit log. Leave empty for all.
rotation
Audit event log files are rotated when they reach a configured threshold log size or are on a configured schedule. When an event log file is rotated, the scheduled consolidation task first renames the active converted file to a time-stamped archive file, and then creates a new active converted event log file.
now
boolean
Manually rotates the audit logs. Optional in PATCH only. Not available in POST.
schedule
audit_schedule
size
integer
Rotates logs based on log size in bytes.
log
_links
_links
format
string
The format in which the logs are generated by consolidation process. Possible values are:
  • xml - Data ONTAP-specific XML log format
  • evtx - Microsoft Windows EVTX log format
    • Default value: 1
    • enum: ["xml", "evtx"]
    • Introduced in: 9.6
retention
retention
rotation
rotation
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
