Retrieve CIFS home directory search paths
Retrieves CIFS home directory search paths, which can help you determine the configuration for locating home directories in your storage environment.
HTTP method and endpoint
GET /protocols/cifs/home-directory/search-paths
Introduced in
ONTAP 9.6
Related ONTAP commands
cifs server home-directory search-path show
path |
string |
query |
False |
Filter by path |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
index |
integer |
query |
False |
Filter by index |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[cifs_search_path] |
"next": {
"href": "/api/resourcelink"
"records": [
"index": 0,
"path": "/HomeDirectory/EngDomain",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
cifs_search_path
This is a list of CIFS home directory search paths. When a CIFS client connects to a home directory share, these paths are searched in the order indicated by the position field to find the home directory of the connected CIFS client.
index |
integer |
The position in the list of paths that is searched to find the home directory of the CIFS client. Not available in POST. |
path |
string |
The file system path that is searched to find the home directory of the CIFS client. |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
