REST API reference
Retrieve CIFS home directory search paths
Retrieves CIFS home directory search paths to access or confirm the configured paths for locating user home directories in your network environment.
HTTP method and endpoint
GET /protocols/cifs/home-directory/search-paths
Introduced in
ONTAP 9.6
  • cifs server home-directory search-path show
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
index
integer
query
False
Filter by index
path
string
query
False
Filter by path
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[cifs_search_path]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "index": 0,
      "path": "/HomeDirectory/EngDomain",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
cifs_search_path
This is a list of CIFS home directory search paths. When a CIFS client connects to a home directory share, these paths are searched in the order indicated by the position field to find the home directory of the connected CIFS client.
index
integer
The position in the list of paths that is searched to find the home directory of the CIFS client. Not available in POST.
path
string
The file system path that is searched to find the home directory of the CIFS client.
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
