Retrieve a share-level ACL on a CIFS share for a user or group
GET /protocols/cifs/shares/{svm.uuid}/{share}/acls/{user_or_group}/{type}
Introduced In: 9.6
Retrieves the share-level ACL on CIFS share for a specified user or group.
Related ONTAP commands
vserver cifs share access-control show
share  |
string  |
path  |
True  |
Share name  |
user_or_group  |
string  |
path  |
True  |
User or group name  |
type  |
string  |
path  |
True  |
User or group type  |
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
permission  |
string  |
Specifies the access rights that a user or group has on the defined CIFS Share. The following values are allowed:
share  |
string  |
CIFS share name  |
svm  |
type  |
string  |
Specifies the type of the user or group to add to the access control list of a CIFS share. The following values are allowed:
user_or_group  |
string  |
Specifies the user or group name to add to the access control list of a CIFS share.  |
      "href": "/api/resourcelink"
  "permission": "string",
  "share": "string",
  "svm": {
    "name": "svm1",
  "type": "string",
  "user_or_group": "ENGDOMAIN\\ad_user"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
