REST API reference
Retrieve a share-level ACL on a CIFS share for a user or group
Retrieves the share-level access control list (ACL) for a specified user or group on a CIFS share. This helps you manage and verify permissions for users or groups accessing the share.
HTTP method and endpoint
GET /protocols/cifs/shares/{svm.uuid}/{share}/acls/{user_or_group}/{type}
Introduced in
ONTAP 9.6
Usage notes
Retrieves the share-level ACL on CIFS share for a specified user or group.
  • vserver cifs share access-control show
share
string
path
True
Share name
user_or_group
string
path
True
User or group name
type
string
path
True
User or group type
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
permission
string
Specifies the access rights that a user or group has on the defined CIFS Share. The following values are allowed:
  • no_access - User does not have CIFS share access
  • read - User has only read access
  • change - User has change access
  • full_control - User has full_control access
share
string
CIFS share name
sid
string
Specifies the user or group secure identifier (SID).
svm
svm
type
string
Specifies the type of the user or group to add to the access control list of a CIFS share. The following values are allowed:
  • windows - Windows user or group
  • unix_user - UNIX user
  • unix_group - UNIX group
unix_id
integer
Specifies the UNIX user or group identifier (UID/GID).
user_or_group
string
Specifies the user or group name to add to the access control list of a CIFS share.
      "href": "/api/resourcelink"
  "permission": "string",
  "share": "string",
  "sid": "S-1-5-21-256008430-3394229847-3930036330-1001",
  "svm": {
    "name": "svm1",
  "type": "string",
  "unix_id": 100,
  "user_or_group": "ENGDOMAIN\\ad_user"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
