REST API reference
Retrieves the share-level acl on cifs share for a specified user or group
learn more
  • [doc /protocols/cifs/shares/{svmuuid}/{share}/acls](#docs-nas-protocols_cifs_shares_{svmuuid}_{share}_acls)
GET /protocols/cifs/shares/{svm.uuid}/{share}/acls/{user_or_group}/{type}
Retrieves the share-level ACL on CIFS share for a specified user or group.
  • vserver cifs share access-control show
svm.uuid
string
path
True
share
string
path
True
Share name
user_or_group
string
path
True
User or group name
type
string
path
True
User or group type
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
permission
string
Specifies the access rights that a user or group has on the defined CIFS Share. The following values are allowed:
  • no_access - User does not have CIFS share access
  • read - User has only read access
  • change - User has change access
  • full_control - User has full_control access
type
string
Specifies the type of the user or group to add to the access control list of a CIFS share. The following values are allowed:
  • windows - Windows user or group
  • unix_user - UNIX user
  • unix_group - UNIX group
user_or_group
string
Specifies the user or group name to add to the access control list of a CIFS share.
      "href": "/api/resourcelink"
  "permission": "string",
  "type": "string",
  "user_or_group": "ENGDOMAIN\\ad_user"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
